M MJarreau Well Known Member Apr 15, 2021 #1 Fluting went well (thanks to the EAA video!). Holes are all straight. Can the webs of the two parts (which are back-to-back) be bowed apart just a bit if the rivets are properly installed? Thanks, Mike
M MJarreau Well Known Member Apr 15, 2021 #2 This was not really an issue. It turned out we had not finished the fluting. Once that was done, everything was nice and flush. FYI: the fluting method we used was learned from https://www.eaa.org/Videos/Hints-for-Homebuilders/Sheet-Metal/1786897202001 Hope this helps someone else! Best regards, Mike
