PAGE 31-03
meadeduck
...step 5, my drawing of the WH-RV12SL-ANT shows two wires coming off the 90 deg BNC fitting. Ours only has one wire; what's the other one????
Meade and George
#16:confused:
The other wire you are seeing does not relate to the 90 degree BNC. It is probably the transponder lead. Each BNC only has one wire.
90deg BNC
It is actually 2 separate cables. The 90 deg is for the radio antenna(SL-Ant) cable. The other one is for the transponder antenna(TX-Ant) cable. Transponder antenna cable isn't covered in the instructions for some reason.
