...step 5, my drawing of the WH-RV12SL-ANT shows two wires coming off the 90 deg BNC fitting. Ours only has one wire; what's the other one????
Meade and George
#16
It is actually 2 separate cables. The 90 deg is for the radio antenna(SL-Ant) cable. The other one is for the transponder antenna(TX-Ant) cable. Transponder antenna cable isn't covered in the instructions for some reason.
