WingedFrog
I found a few hints on the "usual suspects" web sites on how to debur this 4 ft long tube inside. The best I found is a file attached to a broom. Has anyone got a better solution? (no offense for the broom handler!
I took a piece of music wire and bent 1/4" of the tip 45 degrees. Then I filed the inside of the bend sharp.
After bending a handle on the other end, the entire tool is about three or four inches long.
It's been an excellent tool for deburring inside holes for the last 40 years.
Dave
[/URL]I found a few hints on the "usual suspects" web sites on how to debur this 4 ft long tube inside. The best I found is a file attached to a broom. Has anyone got a better solution? (no offense for the broom handler!)
If you really want to deburr the inside
Make a Inside deburrig tool by taking a 5/16? x 36? drill rod, then cut a 1?slot in the end with a hacksaw.
Insert a strip of sand paper in the slot and wrap it around the drill rod, the opposite the rotation of your drill.
This tool comes in handy to have in your shop.
Good luck
Joe, that might work on aluminum, but those stainless steel burrs will shred the sandpaper in an instant.
Tony
