https://hosting.photobucket.com/images/zz149/md9680/Capture_X.JPG
I've marked the areas on the spar flange that are not to be used to match drill the holes in the lower short J-Channel. However, I notice that the end of that J-channel is almost right over where, presumably, a machine screw will eventually be. I've verified several times the length and position of the channel. Don't want to screw this up and I've measured over and over its length and position. Am I doing something wrong here?
