Steps 3 and 4 advise to only final drill the trailing edge, tip rib, and counterbalance rib where the flanges meet the skins. I would assume the rest of the holes are the newer RV-14 only parts that don't require final drilling (spar and stiffeners).
With that being said step 6 states debur all holes and edges that have not been deburred. Does it mean all holes that you Final / Match drilled in step 3 and 4 or "all holes"?
I only ask because it is a big difference in the amount of work. Thanks
