P10-08 WH-P30 Pitch Trim Wire
gblwy
Patron
Hi,
The 5-strand wire for the trim has pins at one end, and bare wire at the other. Can anyone advise which end attaches to the trim motor?
Thanks...Keith
The end with the pins will go to the instrument panel. You will have to crimp spade connectors to the bare wire ends at the trim motor.
Tony
The pins are on the forward end. The are inserted into a connector at the instrument panel. Terminal lugs are attached to the bare wires near the trim motor.
