I still have the question: Is Brad or Tom a pilot, and are either of them flying behind their product on a regular basis?
Note, I have a qualified history to be asking such a question.
Contact Brad at E-mag, he might know if a customer is doing that.My 7-A build includes one Slick & Lightspeed II.
In a discussion with another builder, we talked about when the time comes to O/H the mag, just replacing it with a P-Mag.
Does anyone run this combo?? Lightspeed II + P-Mag...
I couldn't seem to find any posts that mention this combo...but then there are a bazillion posts about lightspeed & p-mags.
I, also am glad to hear that the E-mags & P-mags are now performing well.
Great concept!
There is a "hard" timing reference point in the Pmag that is converted by the software magic to a "soft" timing point with the blow in the tube method. Some time ago, there were reports of the Pmags getting their brains scrambled and reverting back to the hard reference point. Since this could be a long way from the soft point, I felt it was better to simply time the mag to its mechanical reference from the start. If I ever do get a glitch, at least the timing will end up back where I thought it was.
Michael,
...Emag has since fixed this problem and there have been no reported problems of lost timing in since, regardless of which timing method you use.
FWIW, I only time mine with the blow-in-the-tube method and with the development of the EICommander, I probably have pulled my P-mags/retimed them more than anyone else except for Brad and Tom at Emag.
I didn't even see that referenced in the installation instructions.
If the quick set is bulletproof said:Mike, I time my 113 the same way you do for the same reason. Just call me an old fashion hardware EE. Software can do funny things for funny reasons like a cosmic ray hitting the wrong cell in a RAM. I have steam gauges to back up my flat screen too.
I'm trying to understand the vacuum advance on the p/e-mags.
Specifically, would one have more advance at high altitude WOT than low altitude WOT? (leave out the a versus b map and RPM).
...Using that logic, it seems to me that the B curve is most useful at altitude as that is where you would see the ignition using maximum advance.
Regards
Richard
My understanding is that as you go to higher altitudes WOT the MP will decrease, causing an increase in advance
