Toggle for P-lead, breaker above it for power.
What switch/buttons did you use?
I used a three position toggle switch. Down mag cold - is p-lead open (off), power off. Up is mag hot- p-lead grounded, power on, center is test- p-lead grounded, power off.
Works for me.
Using the Stein Switch
MOM Test (Up): E-Mag Power interrupted. Ignition On (P-Lead Open)
Center: E-Mag Power On, Ignition On (P-Lead Open)
Down: Power On, Ignition Off (P-Lead) Grounded)
Are you sure? Looks like you have the p-lead logic reversed.
Don’t forget to turn off the ‘other mag’ when doing this test.
Hard to understand how the above makes sense or makes things simpler, you still need breakers for power.![]()
I used the Aeroelectric 3-position switch design (OFF/ON/BAT) with a single switch to place both Pmags in setup mode for timing.
No issues 11+ years.
I can do basically the same thing using my VPX that supplies power to the EMAGS.
Actually don't turn off the other Emag when doing this test. If the other mag is off and this test fails your engine stops. When running this test if it fails if you see an RPM drop this would due to the loss of the internal E-Mag power source which you are verifying when you go to the MOM up position. See the internal power transition of E-Mags https://emagair.com/114-series/...
This is straight for the manual:
1) Ramp Checks (roughly 1700 RPM).
a) Internal Alternator - E-MAG internal alternator operates in parallel with power supplied by the aircraft bus. The ignition automatically transitions between aircraft power and internal alternator power as needed. Aircraft power is required for starting and low idle speeds.
i) Running on one ignition only, turn ignition power test switch OFF for 2-3 seconds and back ON. The engine should run smooth during the momentary bus power outage, verifying the internal alternator is working.
ii) Repeat with the other ignition.
iii) The left/right Ramp Check rpm drops may be quite a bit different with E-MAGs than magnetos. We don’t apply the same rules to gauge ignition health. Any rough or degraded behavior (before, during, or after each side’s Ramp Check) indicates a problem - not suitable for flight.
This thread makes me glad I have mags![]()
If you use buttons to test your P Mags, what hardware did you select? I was going to use an Otto P3 for mine, but the contacts are so small, they did not seem robust enough.
Compare to a Honeywell TL:
Did anyone actually answer rocketdoc's question? (didnt see it)
Im interested in the answer.
This question . . .
I assume Scott is looking for a push button, SPST, momentary, normally closed switch. My concern is how does a switch like that fail. Open or closed? Hopefully closed.
