Original AV control module
gblwy
Patron
Hi,
After 7 years of service the plane suffered a complete electrical failure after switching off the Master Switch, or possibly at the subsequent switch on. There was no sign of life whatsoever. The battery was fully charged.
After significant diagnosis the fault was isolated to the control module, with a suspicion that the master switch was the culprit. In fact the switch was OK but one of the PCB tracks in the vicinity of the switch was found to be bubbling, a sign of excessive heat. The cooling fans were working correctly.
A competent electronics friend spotted the problem, and repaired it by soldering a wire to bypass the bad area. This involved removing the back plate from the module, and temporarily removing the large capacitor to allow access to the affected area. His view was that the track size was marginal, having measured the current flow.
The plane is now up and running but it begs the question what happens if the module has to be repaired/replaced. Can a replacement be ordered, and at what potential cost bearing in mind that this unit is no longer supplied? Should this, unusual, problem be formally reported to Vans? Scott?
Incidentally, all of the switches are soldered to the PCB and are therefore not readily replaceable. And for the same reason the PCB is not readily accessible for inspection or repair.
Thanks...Keith Boardman
I had same thing happen last summer. In my case the master relay solenoid mounted to front of firewall failed and caused foil burn as you described. I called Van's and new replacement switch/circuit board was ~$700USD and is available. This is first generation switch panel. I have RV-12 SN 120058.
In my case I couldn't access the burned foil (much less see it) so I soldered hard wire from master switch terminal and ran wire directly to master relay solenoid on firewall. Worked a charm. Also, replaced master relay solenoid on firewall which was root cause of my problem.
I also did a "Macgyver" fix to the Stabilator electric trim control because I got fed up with the PWM on the circuit board. I am very pleased with this fix. See...http://www.vansairforce.com/community/showpost.php?p=1202259&postcount=299
Ingenuity is the Mother of Invention...
Hi,
When production ended on the D-180 avionics kit, a bunch of spares were built an put into inventory so they are available.
I am only aware of one spare being purchased since production ended.
There should be some available in the used market as some aircraft have been updated to 10" Skyview systems...
Meantimes between system failures analysis....
Is it a matter of when, not if, the master relay will cause this to happen to all RV-12's, as they age? Any trend analysis except to say this happened to two aircraft in recent years??
I guess it depends on how you define "trend".
These two failures mentioned are the only ones I am aware of (now, because of them being mentioned here in the forum). Besides knowing they happened, there is has been no other info provided (total time in service, etc.)
By regulation, any failure in an S-LSA RV-12 is required to be reported using the form or on-line process detailed in the Maint Manual. For E-LSA, it is desired (and in the best interest of the RV-12 community as a whole) but there is nothing regulator to require an owner to do so.
