B bobg56 Well Known Member Patron May 22, 2026 #1 Has anyone installed one and if you had does the "burp" line that comes from the lower crank case fitting still go directly to the oil tank inlet fitting?
S seagull Well Known Member May 22, 2026 #2 I have one installed in mine, here is some info; Thermostatis kit – Seagull
