Oil sender
Smitdog43
Member
Trying to determine what model VDO I need to order. Thanks for help/ advice!
VDO 360430 for dual terminal-
360004 if you want single post version.
There are a number of similar units, look for numbers on the hex portion.
What make of engine monitor are you using?
Thanks!
Had a long talk with ISS. Definitely a 360-004. One last question, what type of thread dope would you use? And the Fuel pressure sender will be getting replaced. Same thread dope or something different since it’s fuel.
Thank you!
Thank you!
Glad you got it sorted out!
Tite-Seal, Permatex #2, or Loctite 565 should work on the sensor threads..
