I have about 20 hours on a overhauled 0-320 E2D. I had low oil pressure right after the overhaul so the engine builder installed a new spring (A White one IIRC) and two washers. Now the pressure seems too high. Goes right up to 80ish on cold starts and typically low/mid 80ties in cruise. Still warm here in UT and I am wondering what's going to happen when it cools off. Aeroshell 100 is currently in use.
Any idea what removing one washer might do? I have a case of XC20-50 for the next oil change. Would this help?
Kirk
Kirk
