Oil pressure sensor malfunction
WillH
I'm New Here
Patron
I believe I have an oil pressure sensor issue and I’m having trouble finding a replacement. Aircraft spruce said the part number is discontinued. Can someone point me in the right direction? I’m attaching a photo of my current sensor.
Rv14 YIO-390-exp119
Garmin has moved to a different type of oil pressure sensor, which uses the same connector. The new part number is 011-05783-30. If you install one, be sure to change your oil pressure sensor configuration to "GPT 150G".
