RVbySDI
I have been troubleshooting Instrument configurations for a while now. I do believe with the help of Sandy and Carlos at GRT I think I have found most all of my gremlins. However, I am still dealing with one last (at least I hope it is the last one) item.
It looks like I have not properly grounded my Oil Pressure sender unit. The sender unit is mounted on the firewall on the manifold supplied in the Van's firewall forward kit. This manifold is also housing the fuel pressure sender unit. My question is: How are you guys grounding this sender unit? Where/how on the unit are you grounding and where is the ground wire running to (engine, firewall, or somewhere else) in order to provide adequate ground? Any pics would be appreciated.
