Oil pressure engine off ?
Python
Active Member
Hi , I have a standard Vans oil pressure gauge on my O 320 RV 6 it is showing about 10 psi
with master on , engine not running ? When I turn master off it goes back to zero. Anyone had this happen ? Or any ideas ?IMG_5232.jpeg
It’s the VDO oil pressure sending unit. Common failure mode.
Yes I recently had exactly the same thing happen. Replaced the sending unit and all was well. Pretty cheap for an “airplane part,” too—thank you once again, boating industry. 🤣
That is the ONLY gauge that I must have a backup for.....
It is the only gauge that can cause you to do a cautionary landing when not needed.
