I have a horizontal Lyc Oil Filter Adapter that uses the 48110-. I red loctited an adapter so it now takes a 3/4"-16 thread female oil filter.
The oil filter adapter has an internal bypass, but can now take a K&N HP-2004, the shorter 3/4"x16 threaded filter, a Napa 1068 or a Wix 51068. The longer filters have much more media but are a bit long at 5 plus inches, for my fit. The longers are Wix 51515, Napa 1515 or K&N HP-3001.
That said, K&N is now South Korean owned and no longer made in the USA. Can wall is thinner and there was a rash of leaks at the welded nuts of those made in Mexico or Korea.
I have a Wix 51068 ready for next time. Easy to add a worm drive clamp with safety wire, if desired. All have a bypass at 8-11 PSID if you don't have a bypass in your oil filter adapter and usually use a 48108- filter.
Throw darts if I goofed any info.
