Now that the winter is coming, one of my todo lists needs to get done: I'm going to install one of those shutters on my baffle-mounted oil cooler. In the summer, my oil temperature remains between 165F and 185F, which is a little on the cool side, but within Lycoming's desired range. But in the winter, it's between 145F and 165F sometimes getting as low as 130F in cruise. Too cold for oil!
For those of you who have installed a shutter, do you find you need to control it while flying? My current plan is to just run the pull cable over to the oil door, so I can adjust it once in a while when days get cold. I don't think I really need to be playing with it while flying, as long as my temps remain safe. Ideally, I'd just have a "summer" setting (wide open) and "winter" setting, and just adjust it twice a year. Do I really need to make this complicated and run the pull cable through the firewall?
What are your thoughts?
