This is in “Temporary” as it concerns a friend’s airplane (not RV).
I’m reaching out to the collective mind in hope of opinion, especially if one here has or had a 1975 or similar Piper Warrior.
Mods, remove this thread if inappropriate.
For a while now, the pilot (not new to this plane) complains of high oil temps. 235F in climb, 220F in cruise.
STD O-320
Talked to me about it, first thing I asked, “Is the winter kit removed?”
He says that it is.
He mentioned this high temp to his mechanic and he changed the Vernatherm “for diagnostic purposes”.
No improvement in temps.
I suggested to check the temp sensor in hot water. Not done yet.
The owner is also suspecting the cooler.
I went for a short flight with him and I confirm the high temps. In cruise, reducing the RPM by 100 produced a 10F drop.
8C at 4500 ft
(boy this is slow compared to the 8 !!)
POH says oil temps are “green” all the way to the red line at 245F. Typical Lycoming data.
After landing, I popped the cowl open and saw this !!
Owner is convinced that this is not part of the winter kit.
The mechanic might not have seen this, or maybe he has, I don’t know.
I never owned a Warrior, although I flew one decades ago and never worried about high oil temps.
If this were mine and I was concerned about high oil temps, I’d remove or have remove this plate for “diagnostic purposes”.
Ready to receive opinions, especially if you know about Warriors.
(edited to add info)
STD O-320
He says that it is.
8C at 4500 ft
