Weasel
Most of us gear-heads like to work on engines and fiddle around under the hood of things. Time changes things and I dont know if its just me getting old or what! ![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am starting to dread changing the oil. It is a maintenance item that takes quite a bit of my time.
The steps required to preform the process are not hard, in fact they are quite simple.
I have a check list of items that I do or inspect at oil change.
Doing this at a normal work pace usually takes me 2-3 hrs.
I fly over 300hrs a year so I find myself doing this every 2 months or so. Is there a way to streamline the process? I use tach time to determine oil change intervals due to flight frequency. Maybe I just don't have enough to do so I get cranky about the small things....![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here the Oshkosh dust is being wiped off while the oil is draining![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- Remove Cowling
- Drain Oil
- Remove oil filter
- Install new oil filter
- Cut old oil filter open and inspect
- Inspect engine for leaks
- Inspect engine controls
- Inspect hoses and wiring
- Inspect engine mount
- Clean engine
- Refill oil sump
- Grease nose wheel pivot
- Test run engine
- Check for leaks again
- Install cowling
![Wing%20wash.jpg](/proxy.php?image=https%3A%2F%2Fblufiles.storage.live.com%2Fy3pzhRBMi-MFg8Asw7NdO5sxzd8o8db0dkOwTOhPW7A17u3aXsH2-UIBhfoINW2lV7V88Lbw2I38PE_2pHBNFXe0vw5d_DLW2cSJM5MlrmVIh3ByXfFPR5akqW4BqDXEZVV%2FWing%2520wash.jpg&hash=347483c7300357ed88afcf65d48c4bb6)
