BonitaRV8
Active Member
I have an AC products oil separator which was working fine up until about 10 hours ago. I now get oil on the belly after each flight. I removed it from the plane thinking it had gotten fouled but every thing was pretty clean. I ran some acetone through it to clean it out but it was pretty clean already. The return line back to the engine was dry with very little oil residue so, I think the oil is just blowing past it and out the exit tube and not back into the engine. I removed the dip stick cap and blew air through the return tube and it was clear. I have the exit tube mounted up inside the cowl about 4-6 inches above the cowl. I guess my question is where do people have their oil breather exit tube mounted and does anyone have the AC Products oil separator? I only have about 125 hours on a new Titan IO370.
