I plan to go with the Odyssey battery instead of the Concord battery. Do I need to order the battery bracket kit from Van's or is there a simple way to modify the stanndard battery tray for the Odyssey battery.
You don't need to actually mod the box per se for the 925 battery. A simple wood block is all that's needed to achieve a nice fit as the battery width(tray fore-aft) is about 3/4" to 1" shorter than the tray. The depth (tray left-right) is fine as is.
Any handy material that you can fab a spacer out of will work. The wood block I used is like 1"x3"x3/4" and painted weighs an oz, maybe 2 at the most. So unless you fab it out of steel, weight is not a concern. Even if it did add weight, weight in the back of a 10 is a good thing to some degree.
On the Van's WEB site its fifty dollars for the battery mod kit. Maybe its got gold trim on it or something. I will go with the your ideas. John, if you can get a photo that would be great.
Eric, this is what I found on the Vans sites. And why my question for the group.
Installation Kit for Odyssey battery
Part Number = ES PC680 INSTALL KIT
Price = $50.00
QuantitySubmit
So here's what we did.. Made a tray large enough to hold two PC680s with a divider so they don't touch, for cooling. Pretty simple.
(Wiring is still in progress and a bunch of that is waiting for a home, so it's messy right now)
Geoff, thanks for the photo. Im going with the single battery set up and thats simple enough to modify. If I was going with two batteries, The photo's John sent looks like it would be the way to go. Once again, thanks all. As always, your expertise it priceless.
I'm just at the point of final assembling the tailcone now.
I really haven't put a ton of thought into the electrical system just yet.
I assume most of you guys just leave the battery tray stock for now and then come back
and do any mods needed if you decide to go the dual battery route, or chose a single battery that doesn't fit the stock tray?
