Nylon T from brake reservoir
Smitdog43
Member
Part F271-N- 04X02 is weeping want to replace with brass. Any suggestions? Thanks!
Steve
713-502-9081
I purchased the new fitting at my local hydraulic hose shop. The only issue is you can't remove the metal keepers and nylon nuts from the plastic brake lines without possibly damaging those plastic lines. Those items are no longer used but they're not seen anyway.
