NorthernRV4
So I have been plugging away on my elevators since last winter and I was dimpling the RH elevator skin rivet holes having fit and drilled the skin to the frame. Well I goofed and clipped the opposing skin with the hammer while using the c-frame. Hindsight being what it is, I suppose I should have waited to get the 3" yoke and squeezed them but... As things sometimes do, they go from bad to worse trying to fix the first mistake. I tried flattening the slight crease out with a few small hits of the flat set against the backplate. All that ended up doing was adding some slight deformations and marring the surface. Oh did I mention this is on the top? Darn Murphy's law! After steaming about it most of the night, I had another look at it this morning and I think it's only a matter of a little filler then primer but I wanted to get a second opinion (or 10) on it. The slight crease is right at the end of the stiffener where it (almost) meets the spar. It seems to be a point of higher stress but I don't know if it might be a problem down the road. Replacing the skin basically means rebuilding the entire RH elevator from scratch because it's match drilled already to the frame. Thoughts?
Arrrrgh by Jim Soutar, on Flickr
The picture makes it look better than it is really. In reality there is more irregularity to the surface than can be seen.
![](/proxy.php?image=https%3A%2F%2Ffarm1.staticflickr.com%2F727%2F20875877481_7cdaf676f5_b.jpg&hash=bb711e60d490facd1c6833656e6f0995)
