No, this is not Vlad's tire!
I had someone ask me about a leak he had on one of his brakes, he thought it was leaking from the o-ring. I suggested that he take it to a buddy of mine who was closer to him and retired, he'd have more time than I did right now. I actually replaced a cracked leaking brake line for him back in Nov. last year, while I was at it I flipped his tires, greased his bearings, and checked his brake pads also. At that time he was wanting a condition inspection and had a list of things that needed attention. He received the list when he bought the plane, from someone that had a pre-buy insp. done and decided to not buy it. I told him that I did not have the time to do that kind work and suggested that he find a shop that could spend the time on it that it needed. He told me a couple months later that he got the condition insp. done by someone else. It was down for a few weeks. Now today is 9 months from when I worked on the tires and brakes and maybe 7 months since a condition insp. was done by someone else. He showed up at my buddies hangar today to get the leak fixed. When he took the wheel pant off he could not believe it. He told him right away that he had bigger problems than a leak. He showed him the tire and the guy said he did not know it was like that. The other side was almost as bad. The brake pads were worn so bad that the o-ring on the puck was coming so far out that it was leaking but not because the o-ring was bad, because the pads were nearly gone. He said he wondered why they were making so much noise. Yes, that is the inter tube poking out of the 1" hole. So I guess this answers the question, when should I change my tires. Well da, when the tube pokes out. You would actually have to look at them to see this though.
My buddy told him to go buy a lottery ticket, because he was a very lucky guy!
