The biggest disadvantage in not priming is in resale. If you have not primed the interior, you have given the potential buyer a lever arm.Hi, If I ever buy a kit, I'd rather not prime as I am sure the plane with out live me. I've hear people say that they primed but that they probably wouldn't prime their next plane. Does anyone regret not priming their plane? I would be building in central PA.
Thank you
IMHO, the only reason---unless you do live in a wet or salty area.The biggest disadvantage in not priming is in resale. If you have not primed the interior, you have given the potential buyer a lever arm.
I didn’t prime the interior except for the home depot etching primer spray can where the parts are mated. I save a few pounds like this. I doubt a future buyer will care if the primer is used. If they do, I will gladly point out all the Cessna sitting on the ramp with zero primer.Hi, If I ever buy a kit, I'd rather not prime as I am sure the plane with out live me. I've hear people say that they primed but that they probably wouldn't prime their next plane. Does anyone regret not priming their plane? I would be building in central PA.
Thank you
I just use my accelerator pump without priming. Two full pumps usually does it.Hi, If I ever buy a kit, I'd rather not prime as I am sure the plane with out live me. I've hear people say that they primed but that they probably wouldn't prime their next plane. Does anyone regret not priming their plane? I would be building in central PA.
Thank you
Do not EVER use CorrosionX or ACF-50 before you paint the exterior as it will weep for a long time and cause major issues with paint adhesion. Once the aircraft is painted, they are great products.Don’t forget the other alternative, which is to treat periodically with ACF-50, or any other equivalent corrosion
inhibitor. I know they can be a little bit messy, but that’s normally because it’s put on too heavy. I’ve been using this stuff for years and think that it works pretty well.
NoEither way, the aircraft will likely outlast the builder. Do you want to build an aircraft to last 100 years or 150 years?
Thanks for the photosThis is what aluminum corrosion on a unprimed wing skin of a 182 looks like after 44 years of service, probably mostly tied down outside for most of its life. The plane is actively flying today
View attachment 68002View attachment 68003
This is the key. The alclad will outlast most of us. Also in order to prime the metal correctly per aerospace standard, the metal must be pre-treated using the Alodine method prior to the application of primer. I know many builders skipped the Alodine step. I also know the the Alodine process is laborious, including scuffing the aluminum, cleaning, rinse, apply acid etching, rinse off, then alodine, and rinse. It is a messy process before you apply a 2mil layer of epoxy primer. You can Alodine a wing rib but do you have a facility to Alodine a large wing skin, a large fuselage panel, etc?Prime if you want, it will add significant build time, effort, some weight, and cost.
Thanks, this perspective helps a lot.ersonally, I Alodined every piece of aluminum in my RV8. This process took days and days and days. I wore out at least two bundles of the purple Scotchbrite pads doing this. The accidental acid splashing corroded a few pairs of jeans. I tried to forget the toxic chromate exposure on my body too. Just want to put things into perspective.
This has not been my experience. Once I have enough parts prepped and ready for priming it only takes me maybe 90 minutes to scuff the parts with PreKote, hang them on my priming rack, spray them with Akzo and clean up afterwards. For me, priming has been less than 1% of my build time.Prime if you want, it will add significant build time...
I've primed virtually everything (live near the coast - even with that, on the next plane I will only prime mating surfaces). I haven't tracked how much time it's taken, but it's really pretty minimal relative to other build activities. For me, the biggest annoyance of priming is the fact that waiting to prime batches sometimes requires you to juggle the order you do final assembly in. In the winter when it was harder to prime due to the temperature, I'd have to just move from one major assembly to another, even though my preference would have been to completely finish one before the other. It's not a huge deal, but it did cause me to lose motivation at times because I didn't see assemblies go together, only the parts pile grow for priming.This has not been my experience. Once I have enough parts prepped and ready for priming it only takes me maybe 90 minutes to scuff the parts with PreKote, hang them on my priming rack, spray them with Akzo and clean up afterwards. For me, priming has been less than 1% of my build time.
Now if I was priming parts every couple of days rather than gathering all the parts I need for an assembly before priming them, then yes, it would add significant time to the build. Maybe that's what everybody else does and why it takes so much time for them to prime? I dunno. I'm a new builder so maybe I'm doing it wrong.
I watched build videos of a guy building a 14A in San Fransisco. I think he primed this way. I think this is what I will do too.(live near the coast - even with that, on the next plane I will only prime mating surfaces).
