I have installed the nose wheel axle bolt with all the spacer and washers per plan and it looks to be a bit too short. When I tighten the nut to a minimum of 90 inch/lb I am still one or two threads short of getting to the nylon portion of the nut but everything else looks OK. There is some friction on the wheel so it is certainly not turning freely but not too much friction and more importantly, the rubber on the bearing is not turning with the wheel. If I tighten the nut to get to the nylon portion then the friction on the wheel increases to the point that I don?t think it is right.
I was wondering if anyone else has ran into this issue. I could get a longer bolt (AN6-66A) but I am wondering if something is amiss if I am the only one that has ran into this issue.
