AlexPeterson
As I've written in previous posts, I have concerns with the current nose wheel bearing/axle setup. My understanding of the current nose wheel setup is that there are two axle adapters, which are against the roller bearings. The bearing preload is determined by how tight the bolt is/isn't.
It would seem that this system is not overly rigid. Under loads, the bolt will attempt to flex somewhat. When this flexing occurs, there is an increase in the bearing load on the load side, and an unloading on the opposite side. The deflections could be very, very small, yet still have a large effect.
Is it possible that runaway bearing drag is contributing to the nose-over incidents? It is not hard to imagine that there is a whole range of states of bearing pre-load out there, from sloppy to tight.
There are two things which could contribute positive feedback (forces which feed on themselves) in this system. One is that as the nose wheel hits a bump, the axle bolt flexes, increasing the rolling drag of the bearings. This in turn pushes the nose gear aft, which tends to increase the load even more and so forth and so on (the pole vault). Of course, once into pole vault mode, it is up and over.
I will work on some range finding force estimates over the next days.
BTW, my nose wheel bearing setup seems to be an anomaly, received in about 1997 or so. Here is a picture of the basic components:
Sorry about the crummy cell phone picture, but you can see that there is a large, about 1" diameter, hollow bar which goes all the way through. The bearing retainers are simply hollow cylinders. The lengths of the various parts needs to be correct for bearing preload, or shims need be used to set the preload. The important feature is that the bolt is torqued to nominal values, and the stack becomes very rigid compared to just a bolt. Does anyone else have this setup? It is simply what came from Van's with my kit.
I would welcome others' thoughts about this possible explanation for nose gear problems. Like many others, I was very, very humbled by that video of the 7A in England.
Something just does not make sense, perhaps this could explain it?
As an aside, I do not believe that a wheel fairing would have had any effect on the outcome, as once things have deflected enough for the nut to drag, it would seem to be all over.
Due to the serious nature of this, it would be very helpful to this thread if we could keep it on the engineering topic discussed above - thanks.
![66AP%20front%20wheel%20bearing.jpg](/proxy.php?image=http%3A%2F%2Flh3.ggpht.com%2F_Tmi66Ai4XWs%2FTJqn39n5YqI%2FAAAAAAAABPs%2FEGzjmlygARY%2Fs800%2F66AP%2520front%2520wheel%2520bearing.jpg&hash=be4bc924ebea06b97ecf3ada20d85a69)
