Daida
Hi folks,
i am about to install a Dynon skyview system, which i am going to order soon.
in the manual it says to keep megnetic materials as far away from the ADAHRS modul as possible, at least 2 feet.
i will install the ADAHRS modul behind the baggage compartment on a bridge, between the two top longerons, made of aluminum angles and a aluminum plate. (as many of others have done it, pics are in other threads).
Here are my questions:
is non magnetic mounting hardware for the ADAHRS modul provided by Dynon?
if not, where did you buy yours?
Did you go with Brass, Aluminum or Plastic bolts/screws?
thanks for your answers!
mit Fliegergruss
Daida
mit Fliegergruss
Daida
