The standard to meet is well defined in ICAO Annex 16 chapter 6 and 10. It tells you how much noise the aircraft is allowed to make and how to measure it.
I am the chairman of the Dutch Noise Measurement team and we we have been talking to a group of RV owners in the UK to perform the noise measurement for them. The problem is/was that our team can perform the noise measurement and provide a
noise report. Basically this is a document stating the amount of noise your aircraft makes in dB(A). But we can not issue a noise
*certificate* as those can only be provided by the Authority that issued the CofA. LAA is not prepared to issue the certificate because it is not required. Besides that, there a more legal requirements, like LAA authorizing the Dutch team to perform the measurements or officially recognizing their reports.
So, if your state of registration does not require a noise certificate, doing a noise test elsewhere does not always solve the problem.
My recommendation to the UK RV pilots for an easy solution, at least for the aerobatic fleet:
I have attached my No-certificate required document. You can persuade LAA to provide such a document. It is 100% compliant with ICAO and is easy to produce.
Having said that, doing a noise test in Germany is very easy. They have two locations where measurements are performed and for non-members of
OUV (German EAA) the costs are around €1200.
A big opportunity was lost when EASA Basic Regulation was introduced many years ago. We had a chance to harmonize EAB into one central European rule base. But the Big Three wanted to keep everything in own hands. Now we are stuck with all those regulations that differ from country to country. But that is very off-topic and I don't want to open a can of worms.
