New Wing Jack
NDrv8r
Advertiser
After someone in our communal hangar took my plane off jacks so he could use the jacks, I decided to build my own. This uses the Harbor Freight 58906 long 3 ton flat jack.
What you get in the kit is the Aluminum frame, hardware, nose cap. We are just ramping up on these, so they are listed as out of stock. These should be available next week in limited volumes. We will also shortly have available screw in jack points that fit the RV7 and likely others that use a 3/8 bolt for the tie down / jack point.
Careful, that design has a collapse mode. I made the same error, and thankfully BillL caught it with his good engineers eye.
Fix was a vertical link to eliminate any possibility of the upper ring sliding on the jack body.
I built these pretty cheap...simple welding exercise. As a hangar-maintenance item I probably didn't need two of them, but as I said....cheap. They've worked very well.
Same collapse mode, plus a buckling mode of the thin buttress leg.
Sorry guys. I don't mean to be critical to be mean. I just don't want to see any dropped airplanes...and flattened mechanics.
while it doesn't likely matter for airplane weight levels, but placing the jack base on top of the bottom aluminum U channels will significantly reduce the weight capacity of the jack. Those pieces will crack long before you reach the jack's capacity and no way they can handle 3 tons. A better design is to leave the jack base alone and build a ring for attaching the support brackets or use flat material like the pic a few posts above.
Realize you didn't ask for a critique, but many come here to borrow ideas and folks should understand any potential flaws.
Larry
