Cadstat
Vitamins
I wish I still had your energy. I tried to do the same approach by building the shop first and then ran out of time to build the RV.
The trick to building is buying from the correct kit manufacturer which you did. The other trick is try to move the project foward a little everyday even if it's only reading about the next step. I've seen too many guys go 12 hour days and then burn out for weeks at a time, myself included. When you bog down, find a buddy with a plane and get some air. AND enjoy the building process. Strive for perfection and accept your limitations. Unless this plane is going directly into the museum, realize that some of the absolutely perfect workmanship will eventually be lost to the harsh and unforgiving environment where you plan to operate that aircraft.
