Larry DeCamp
My diode for the independent EI battery buss has two paths ( two parallel diodes on the diagram). Can/should they be wired in parallel ,ie common power to both inputs and common output wire to the EI buss ? For clarity, this buss is a free standing power supply with battery for the second EI, and continuously charged from the main buss.
BandC has advised is it acceptable to route the field wire through the firewall with the B lead. The only caveat was they have heard of radio noise in unspecified models and configs. Do you have any advice to pass on ?
Comments most appreciated.
