Folks,
I know there are at least a couple of us out here with NavWorx equipment with non-AD related technical issues...while waiting for NavWorx to respond to our technical issue help requests, we should attempt to help each other.
To that end, I have a 6A with a NavWorx ADS600B -13 connected to a 430W, SL-70, and MX-20...
My unit displays "Ready for Flight" and "TX/RX Error", while not actually working. The "TX/RX Error" only showed up after I was able to get the transmitter turned on...which required installation of an older version of software as the "Activate Transmitter" feature had been removed from later software versions - then upgrading to the latest required software.
All of the other attached equipment in my environment appears to be working properly and communicating with the ADS600B -13 unit.
I can offer my environment to help test other folks units that are having technical issues. I would also request that others make available their working environment to test our non-working equipment in as well as known-good equipment for testing in our environment. Since we have some time before the 2020 mandate and don't know the NavWorx ongoing support status - this is most likely our best solution...aside from abandoning the NavWorx hardware and repurchasing an alternate solution.
Thanks for your collective consideration,
