FORANE
I installed a Navworx ADS600-EXP in our RV-9A. It uses the transmon adapter to connect with the transponder - a Garmin GTX320A. It uses the UAT antenna and GPS antenna supplied by Navworx with the ADS600-EXP.
I set the anonymous box to off. I flew it twice since the install.
The link below shows the FAA compliance report. There is a 100% failure of the "emitter cat". Any ideas where to start or what may be the issue?
http://docdro.id/DNdZR7y
