Hello VAF..
Looking for recommendations for NAV antenna setup for two VOR/ILS receivers. I'm installing an IFD540 and a VAL INS429 in RV8
- I’m thinking an antenna in a wingtip would be cleanest.
Q might this choice be a compromise or in anyway less “functional” than traditional external antenna?
- I believe I can split signal from one antenna to both receivers.
Q Might this result in signal compromise, or any sort of degradation as opposed to installing an antenna for each receiver?
Q I believe a duplexer (?) is the required device for inputting LOC and GS info to respective receivers. Is there a preferable make/model?
- the VAL has MB included.
Q is a MB antenna necessary, or can that signal also be derived from NAV antenna?
I love and appreciate the plethora of knowledge and experience in this group.
If you’ve read this far, thanks!!
Bryan
Bryan
