So, today is the first day that I used my b-kool air conditioner in the -10 and I discovered something quite remarkable. I turned the unit off when I reached 6500' and opened my pilot side vent and noticed air speed drop 2 knots. Confused I closed it again and my airspeed came right back. In fact, I played around with a lot of scenarios and found that if I had both front vents open and the rear NACA controller open, I would drop 7kts of air speed. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I repeated the tests on the way home at 9500' with the same results.
Is this common?
Shannon
Is this common?
Shannon
