I originally glued the NACA ramp air inlets to the fuselage using J B Weld epoxy. I also secured the inlet end with a couple of pop rivets. The left air inlet has come loose with only the rivets holding it in place. I'm wondering if anyone has a suggestion for a better glue and a clever way apply it, since there isn't much gap between the inlet and the fuselage.
