RVG8tor
I was under the plane doing some work and happened to creep by the step and thought that seems to have more movement than I remembered.
Sure enough the back side right at the weld and gusset is a crack, just logged 216 hours. Step stool used when in the hangar so it is only used when getting in and out for flight. I always step back onto the step and have my passangers do the same.
This well be kind of a big job as I cut my flap fairing to just fit the step, the flap fairing will have to come off or at least part of it. then all those rivets to remove, I know a good welder and will ask if this is something that can be done with the stop on the plane.
I wonder if a wad of JB Weld would hold things for a few months, I really don't want the airplane down for the summer flying season.
Cheers
These are photos of the crack and step and fairing.
Cheers
