claycookiemonster
The clue bird is circling closer and closer in regards to having a plan to actually installing various electrical bits around the kit.
I'm sorry if other versions of my words have already been said and written here, I just need to say it my way so that my tiny brain is happy. If my words are wrong, please let me know.
This: As each new component arrives in the workshop, eg. stick grips and A/P servos, my plan will be to see how many wires are required for that item.
If it only needs 2-4 wires, I will forgo a connector. Instead, I'm going to crimp female D-sub pins onto each of them. Then, I will crimp male D-sub pins onto the end of similar gauge wire, marking both ends of that wire with the color code of the original lead it will be connected to. Finally, the joint will be covered in heat shrink, and made semi-permanent.
If the component has more than 2-4 wires, I will crimp female and male D-sub pins as above, except now I will use an actual D-sub connector with the appropriate number of pins to make the connection.
I have been frozen, looking at wires dangling from aileron trim motors and heated pitot tubes and roll servos, wondering how to manage them. Now wired stick grips have arrived, only making things worse. So, this is my plan to deal with this: Female pins on the unit. Male pins on the leads to the unit. Simple heat shrink connections where there are few wires, and D-sub connectors where there are 5 or more.
What have I forgotten?
