Hi All,
I need to move my partially completed RV-14 taildragger from Arizona to Texas in the next 2-3 months. I’m trying to figure out the best/safest way to do that. I’ve been reading various threads about it. I wanted to get advice from anyone that's done it.
My RV-14 fuselage is on its gear, the engine is mounted, prop is off, canopy and cowling are completed. Avionics are not installed. All tail surfaces are done. VS and HS stab are currently mounted on fuse. Control surfaces are off. Wings are mostly complete and on a cradle.
I’ve read that for a taildragger trailered in the 3-point attitude its vital the VS be mounted to the fuselage as loads are transmitted through it. If the VS is not mounted to the fuselage, you run the risk if bending the aft fuselage as it bounces down the road on its landing gear.
1. If true, does the actual VS have to mounted to the fuselage? Or will just having the bolts in place that normally go through the VS aft spar into the aft fuselage F-01412 bulkhead and U-00018 tailwheel mount suffice? The HS stabilizer is too wide to be mounted to the fuselage for trailering. So, if it's not present there is no place for the front of the VS to mount to.
2. If the VS must be mounted to the fuselage and having only the bolts through the aft bulkhead to safely trailer it in the 3-point attitude won’t suffice, can it be safely trailered in the 2-point attitude with the VS removed and a cradle supporting the aft fuselage?
3. Is there any limitation to trailering it forwards or backwards? I can’t think of any.
4. Are there any points on the airframe that I shouldn’t use to tie down on? I plan to have the cowling off so I can use the motor mount tubes, securing it there, at the main tires/landing gear legs and aft tailwheel stinger. The canopy will be on and latched close. I don’t plan on using any straps or tiedowns that go over the top of the fuselage. That just doesn’t seem like a good idea.
5. I’ve heard that Stewart Transport, who ships QB kits, also ships partially completed planes. They seemed to have a good act when they delivered mine. Does anyone have any knowledge about them shipping planes like mine, good or bad? Any photos on how they get a completed fuselage into the truck?
6. Anyone aware of any other companies that move aircraft?
7. Any advice on the kind of trailer you used? Some of the car trailers I've seen are a bit narrow to fit my gear. My main gear track at the outside edge of the tires is 92" wide. The total track width including axle extensions is 96" or 8 ft. Wheelbase from main gear tire to tailwheel is 187" or 15' 7". I was thinking some kind of wider deckover type trailer where the deck extends over the top of the trailer wheels might be more appropriate. I live in the Phoenix area so renting one of these is a possibility.
8. I'm more concerned about the fuselage vs the wings since its bigger and heavier. I'll probably make a second trip to TX with the wings on a car trailer secured in their cradle.
8. If anyone reading this in the Phoenix area has an appropriate trailer for my fuse and would be willing to rent it to me for the move let me know. I'd tow it with a RAM pickup.
I’m not the first person to move a plane in the middle of a build. I need to move mine about 850 miles just want to do so in the safest/least risk manner.
Thanks to all for any advice you can give me. Particularly as it pertains to the VS being mounted or not. Any photos of moving your taildragger, or any type RV, are appreciated too,
Scott Davis
602 290-5363
Scott Davis
602 290-5363
