Veetail88
I ran my motor yesterday for the 2nd time and have a couple of problems. Sorry about the large pictures.
Problem 1, the motor isn't idling. When I start it, and with the throttle all the way back, it's running at 1700 RPM.
I have fuel injection by Precision. I believe the linkage is correct as the throttle lever appears to be against the stop.
I assume that turning down the idle adjustment screw will only increase RPM.
In addition, with only about an inch of throttle movement, the motor winds up to 2700 RPM. I was afraid to move it further.
Problem 2. The mechanical fuel pump is not working correctly.
With the boost pump on, I show around 28 PSI and everything runs smoothly.
When I turn the boost pump off, the fuel pressure drops to around 2 or 3 psi and the motor isn't real happy about that.
I checked the model of the fuel pump and it is LW-15473, which is apparently the high pressure pump, so I didn't end up with a carb pump.
My red cube is between the electric pump and the mechanical pump, but others have said this isn't a problem.
Another has voiced a question that maybe the pump hasn't primed properly. The motor has a total of about 13 minutes run time on my 8.
I purchased it from Mattituck 3.5 years ago and haven't run it before. I assume this would have shown up on the test stand, but it's not like I can call them anymore.
Any help on these items would be appreciated.
Oh, and yea, I'll torque that castle nut and get a cotter pin in it when I get out to the hanger next.
