The mixture cable attach in section 50 was somewhat contradictory in that OP-22 and section 50 and the rv14A wrap around view are all different.
The rod end bearing attaches on the inboard side of the mixture arm in OP-22. In section 50 it attaches on the outboard side. In the wrap around view it attaches on the inboard side but with different nut and bolt orientation from what’s shown in OP-22. Can anyone who has the same servo and 210 hp io390 please confirm that the way I did mine is correct, according to section 50. I found that when the rod end bearing is attached on the inboard side it binds slightly on the servo arm.
I have full travel with 1/16” cushion gap. Cotterpins are not installed yet. Thank you,
