This morning I was finishing up drilling the HS skin and managed to mess up a hole through the skin and HS-702. It was one of the holes that was pre-punched in the skin but not in the spar. I attribute it to a bad drill bit that needed replacing several holes ago. Anyways, my question is how to proceed with this hole. Is this a good candidate for an oops rivet where a bigger hole will eliminate most of the damage in the skin? Or is it something that can be sanded out and then proceed with a normal -3 rivet? Picture is attached but no guarantees it works the first time. I'm still struggling with getting these image links to work. Thanks in advance for any tips.
Dustin
Another Link here that might work:
https://photos.app.goo.gl/UqfMA1tjvjE3rCai7
Dustin
