MartySantic
Went to install the headset jacks. The mic jack requires an ISO washer (this is listed on Jim Cones MIA list so it will be coming) and a stepped washer for the jack (NOT listed on Jim Cones list). Did anyone receive the stepped washer? Will need 2.
ALSO, on the pilot side attached to each lug on the audio jack are short 3" wires that are just hanging. I could explain them if they were on the co-pilot side as the plans give you the option of installing a 1/8" jack to record audio on a camcorder. The 1/8" jack is just paralleled with the co-pilot audio jack.
Should I cut-off the 3" stubs?
