rph142
So I replaced my MGL V10 comm with a MGL V6 comm and now i cant transmit clearly on CTAF or Unicom, but I can transmit clearly at towered airports. When transmitting at ctaf my voice is broken and garbled and virtually unreadable. The towered field I fly out of hears me fine.... I am using the same headset, ground location, antenna/cable, etc that I used on my V10. The only difference is that the shielded PTT cable ends about 3 feet before it gets to the PTT switch. The last 3 feet is just unshielded wire. I am going to fix this next, but if that is causing tx issues, then why not at towered fields? I am seriously confused.
