Rainier Lamers
MGL's own servo development is now in final prototype stage. The MGL servo does not replace the current support for the Trio Avionics Gold standard servo which will remain the mainstream choice but complements application to higher specification areas that require a choice of bellcrank, capstan or linear drives. The MGL servo is fast, not restricted to any particular angles (i.e supports multiple turns if required) and powerful. It has contact free (zero wear), highly accurate and repeatable position feedback to less than 0.2 degrees and is able to measure force for real time trim feedback. Output shaft is supported by two ball bearings for high axial loads.
The stepper motor based servo is mounting compatible to Dynon/Trutrak format but has a thicker main body to allow for oversized gears and fully integrated electronics.
The MGL servo supports MGL's open servo control protocol either via CAN bus or RS232 and will be freely available to third party users.
Final pricing is not yet known but is expected to be less than $1000 per unit. MGL expects release of first units in 2nd quarter 2010.
Rainier
CEO MGL Avionics
Rainier
CEO MGL Avionics
