Flying again!
I just did a condition inspection and found that the prop control cable on my -10 had melted the outside cover (it passes along the left side of the sump and up to the govenor at the front left of the O-540.
Troy Thompson who signed off on the inspection said he thought it was from heat soak. He said during a group X-country one of the RV-8s had the throttle freeze after a refueing stop. Apparently it got so hot that the inner liner melted and froze the cable.
Mine was not that bad and it still functions normally. However, I bought HeatShield 270012 Thermaflect Sleeve 1/2" ID x 3' Heat Shield Sleeve for $16 from Amazon. It is rated for 1100 degrees F. I saw some evidence of the same with the throttle and mixture cables too.
The strange thing is that the -10 has over 360 hours and I have owned it for 18 months and over 150 hours. I check the engine very carefully at each oil change and did not see any damage at the end of October during the last oil change.
Here a a couple of pictures.
[/IMG]
![PropCable3_zpsb85ed724.jpg](/proxy.php?image=http%3A%2F%2Fi1310.photobucket.com%2Falbums%2Fs653%2FStackfamus%2FPropCable3_zpsb85ed724.jpg&hash=4088a57fbfa3138d5428e368c5bddad6)
![PropCable_zps6df83b12.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi1310.photobucket.com%2Falbums%2Fs653%2FStackfamus%2FPropCable_zps6df83b12.jpg&hash=a38595eb285fc0a4660a5caee2780a46)
