Call me a Luddite:
noun
1. DEROGATORY
a person opposed to new technology or ways of working.
"a small-minded Luddite resisting progress"
Well, that might be me, but sometime I have my reasons why new technology isn't better.
Lot's of reasons to not need electrical pitch trim:
1. Manual trim will never run away.
2. In the event of an electrical failure, the trim will still work, and not runaway.
3. Cheaper
4. Can't possibly run away due to a stuck switch.
4. Meets the designer's criteria
5. At least in my RV-6, I might use the pitch trim 3 or 4 times in a cross-country flight, maybe a bit more in a formation flight.
6. The manual trim can be adjusted much more finely, and slowly than the electrical trim.
7. If you are on autopilot, the autopilot will alert you that it isn't happy with the trim setting, and you can smoothly fix it, allowing the human pilot to better remain in synch with the trim status of the airplane.
PS: I still drive a manual shift pickup truck, for many of the same reasons!
The only reason I can think of for anyone to get electrical trim is because you Want it, and it's cool like a big airliner...........
Same for aileron trim.
And if I ever get around to installing adjustable yaw (rudder) trim, it will be Manual, for all the same reasons.
No doubt YMWV.
