blueflyer
So I just installed an overhauled carb on my plane. I was doing a max rpm ground runup. When I did the max rpm ground runup with the new carb, I got to 2250 rpm and it started to stumble a little bit and rpm dropped to about 1900. I then leaned the mixture (throttle still full wide open) and the rpm came back up to 2250. Is it normal to not reach max ground rpm in a full rich mixture condition on the ground? Do you typically need to lean the mixture to achieve max rpm on the ground?
